What could cause tire bubble like this :(
Old 06-17-2010 | 05:21 PM
FREEK's Avatar
Default What could cause tire bubble like this :(
Hello s2ki,
Got a little vibration first, thought just need to rebalance the wheels, after a few short drives vibration became so strong I couldn't even see anything in the mirror.
Today removed one of the rear wheels and found this!
My question is what can possible cause that?
Old 06-17-2010 | 05:31 PM
SpudRacer's Avatar
Looks like a broken belt. Also looks like that tire is worn beyond its useful life.
Old 06-17-2010 | 05:42 PM
wisdom's Avatar
That tire still has thread left. The thread has not worn down to the wear bars.
As far as the bubble, I have no idea. What does a warranty cover?
Old 06-17-2010 | 05:43 PM
Mr. Francesco's Avatar
Defective I would say, but I can't see how a defect wouldn't show right away. I agree above, most likely a worn or bad belt.
Old 06-17-2010 | 05:52 PM
KchaoS2K's Avatar
have u ever had the tire repaired? if not it could be a install issue with a ripped bead? sometimes when u have a tire puncture and it gets patched or plug some times the patch holds externally. and the air leaks out inside the belts. it can also be caused my tire separation due to poor alignment.
Old 06-17-2010 | 06:54 PM
nickp's Avatar
thats a broken belt in the tire i would not drive on it its ready to BLOW! lol time for new tires gl
Old 06-17-2010 | 07:23 PM
2poor2mod's Avatar
Ouch, def a shifted belt, but it looks like it was about time to replace the tires anyway.
Old 06-17-2010 | 07:34 PM
FREEK's Avatar
I thought that much protector would live till end of this season on streets...
Anyway, time to get new tires
Old 06-17-2010 | 08:13 PM
CT S2K's Avatar
time for tires away
Old 06-17-2010 | 10:07 PM
Mar48's Avatar
the outsides (on the side the bubble happened) are to the wear bar so you should replace regardless
