Weight of '04 wheel vs '03 wheel
MY '04 wheels: (no tires)
Front: 17.7lbs
Rear: ~20lbs
MY '00-'03 wheels: (no tires)
Front: 17.5lbs
Rear: 18.5lbs
Not sure why you're asking but if it is because you are considering aftermarket rims there is certainly room for improvement in the weight department.
Front: 17.7lbs
Rear: ~20lbs
Front: 17.5lbs
Rear: 18.5lbs
Well as of now my plans are using the OEM 16's for snow tires and the OEM 17's for summer tires. However if the OEM 17's were real heavy 20+ lbs each I'd rather go aftermarket. There's something comforting about using OEM offset and hubcentric wheels.
KAMcDonald is making an excellent point though. The weight of the wheel is helpful to know when you are trying to decide between 2 new wheels (of the same size). But the combined weight of the wheel and tire is helpful to know what affect it will have versus what you have now...
Aftermarket wheels can be had with offsets that are almost identical to stock...
According to Jeff @ Evolution, did a quick board search, A Honda dealership put a set on the scale, 14lbs for the front and 15lbs for the rear each, now I don't know the validity of this Mark, so take it with a grain of salt.
Luke
btw: go back to PO
Luke
btw: go back to PO
