Volks and center caps falling off
As the topic says i got a set of Volk Ce28 with the flat center caps. but my problem is that they pop out when im tracking the car
Last time i lost on at the track and on popped out in the pit after a good run.
Any one got the same problem and know how i can solv it ? (No i dont whant to run with out then )
Thank you
Thank you
strange, mine are in so tight that its a pain to get them out when im trying to clean the wheel. you still have the rubber grommet that goes around it? absolute worst case scenario add some loctite on the rim when you are sliding it in.
Its 2 rings on the caps. Missed 1 up front on the track and 1 back in the pit. The one it the pit poped out (Jumped 2m or somthing from the car) Think that was cus of the heat. Maby its building up some presure behind it. They are sitting hard as hell usaly cant get em out without take the wheel of and push em out from behind.
Its 18x7,5 50 offset in the front and 18x8,5 52 offsett in the back
Originally Posted by Harpoon,Jul 31 2009, 04:10 PM
Weird. I don't get it.
By the way - does your track have a problem with cars running caps? Some do because of safety concerns for corner workers.
Its alitel frustrating. got 2 sets of caps tho. but its alitel frustrating to loose em.
