volks ce28 fit ?
volks ce28 fit ?
hi i'm looking at used volks ce28 and i wan't to know if the size are gonna be ok, I don't want cut roll or do anything on my fender
front 17 7.5 +50
rear 17 8.5 +47
thank you
front 17 7.5 +50
rear 17 8.5 +47
thank you
Site Moderator
It should be ok but it is something to watch. I have seen oem wheels ruin fenders so just check your liners regularly and be careful of driveways. The rear will require more camber when lowered to clear.
It will also depend on the tire size you run as well. Stock height, the fronts are good. I have volks as well, 17x7.5 offset 52 and lowered an inch. I rub the fender tabs some times if I take hard turns because my suspension is soft and run 225.
The rear should be fine even if you lowered it as long as you do a 245 tire. 255 tire will be cutting it close
sofresh&soclean
04-03-2010 04:11 PM
