Volk TE37s
Volk TE37s
I'm going to be buying a set of Volk TE37 in gun metal. What offset do you guys suggest? Also, what tires do you think i should run if im going to be running a turbo? I want a lot of contact in the rear (I know that sounds funny but shhhhhhh)
What size are you guys planning on going with. There arent many choices, each diameter has only one offset i believe that will remotely close.
I just got a set of 16 x 7 42mm front and 16 x 8 46mm rear.
Well, as i said, there really arent any options once you figure out what diameter you want go with. So yes, they are pretty aggressive offset, but they also offer a lot more clearance for bigger brakes.
The 17s come in 7.5 for the front and 8.5 in the rear. I believe they are 48mm and 50mm respectively. Again, not ideal, but many on the board are running them.
Originally posted by mbitton
doc, do you know if they would they stick out with that offset?
Im running a 43mm offset in the front on the same size wheel currently and have no problems at all, even while being lowered.
