Volk EVO IV 17x7 and 17x8 45+ offset
Hi all,
Just wanted to clarify tyre choice to avoid rubbing on about approx 2.5" lowered.
Currently on 18x7.5 35+ offset with 225/40/18 all round and have hit both front fenders at low speed
Im thinking:
Front 17x7 45 offset with 215/45/17
Rear 17x8 45 offset with 235/40/17 or 245/40/17??
Any help would be great...
Im thinking:
hahah thanks for ur comments... i actually dont mind those rims
so the negative camber is for the front or the rear and how much?
Jim.. how much for shipping of 4 tires to melb, aust?
Originally Posted by Mar48,May 19 2010, 06:46 PM
You should test fit them first to determine how much camber you would need.. I had 1.5 in the front and 2.5 in the rear... if you are slammed I think those should work
Originally Posted by Mar48,May 20 2010, 04:55 AM
Thanks for all the help guys.. got the rims on... lifted the font a little and no rubbing.. got a slight rub on the right rear on bumps but will get it sorted when I get a UK spec alignment.
When with
215/45/17 on 17x7 +45
245/40/17 on 17x8 +45
UK Alignment Specs:
front castor 6.45
front camber -1.0 (maybe -1.5)
front toe 0.0
rear camber -2.0 (maybe -3.0)
rear toe 0.20 total 0.40
Before
After
When with
UK Alignment Specs:
front castor 6.45
front toe 0.0
Before
After
