volk ce28 question
#23
Originally Posted by s2kforlife,Apr 16 2009, 10:20 PM
If you rolled your fenders properly, you should run 17x9 +40 with a UK alignment. It will look perfect, and solve your rubbing issue without going to extreme on alignment settings.
A 8.5" +50 will be tucked in 8mm more than the +42 you had. Are you OK with that?
#26
Originally Posted by S2K Driven,Apr 17 2009, 08:09 PM
Maybe i'm not getting something. Wouldnt a 17x9 +40 have a higher chance to rub then a 17x8.5 +50? I also already have a UK alignment.
You either want to run aggressive stance or you don't. 8.5" +50 and 9" +63 are conservative and will work fine, even with stock fenders. If your fenders are rolled and you want the aggressive stance, then go 9" +40. I don't know how else to explain it, you need to make up your mind what you really want.
Stock: 8.5" +65
9" + 63: Out 8mm compared to stock
8.5" +50: Out 15mm compared to stock
9" +40: Out 31mm compared to stock
#27
nate. sorry i cant make up my mind lol.. rims are a hard decision. but i finally decided and you have helped. gonna run 17x7.5 +43 17x8.5+50 thanks for all your help guys..
-Gokhan
-Gokhan
grooveracer
01-30-2004 09:45 AM
