volk CE28 18's need tire but what size?
Old 08-15-2006, 10:48 PM
zenkai_ate_you's Avatar
Default volk CE28 18's need tire but what size?
hi guys i have volk ce28
18by 7.5 front 50+ (i know 225/40/18)
18by 8.5 47+ (what size?) and i dropped about 1.6 on rear..
let me know guys...
Old 08-15-2006, 11:46 PM
Steve@Evolution's Avatar
I would recommend 215/40 18 front and 245/35 18 rear.
You can run 225/40 18 fronts also but try to stay away from 255/35 18 rears.
Steve - Evolution
703-961-9090
Old 08-16-2006, 06:30 AM
vbb
vbb's Avatar
You think he'll rub with 255s and a 1.6" drop?
I get my wheels/tires in today with 255 rears on about a 1.2" drop, so I guess I'll see if it's going to rub later on.
Old 08-16-2006, 08:19 AM
let me know boss
Old 08-16-2006, 11:50 PM
That's why I recommend 215 front and 245 rear to be safe but certain brand of tires are physically skinnier for a 225 so it can get away from rubbing.
Steve - Evolution
703-961-9090
Old 08-18-2006, 04:25 AM
vbb
vbb's Avatar
Originally Posted by zenkai_ate_you,Aug 16 2006, 12:19 PM
let me know boss
No rubbing to speak of for me, running 225s up front and 255s in the rear. Tires are Falken Ziex's
Old 09-10-2006, 06:18 PM
geovong's Avatar
i have the BF goodrich G force T/A tires on same wheels. I run 225/35/18x7.5 front and 255/40/18x8.5 +47 offset rear with 1" eibach spring drop. I have s serious rubbing issue with my rear.
What is wrong with this set up? What should i do?
Old 09-10-2006, 08:25 PM
racerfan's Avatar
what brand of tires are physically skinnier and stuff?
Old 09-11-2006, 02:04 PM
ignition25's Avatar
heard that some Toyo's are thinner.. but I'd check the tire specs (tirerack has most of them) to compare
Old 09-11-2006, 09:57 PM
racerfan's Avatar
the fronts should be 225/40/18 and the rears should be 255/35/18
if you got a 40 series in the rear the tires may be way too tall and also the brand of tires bf goodrich i'm sure isn't a rounded sidewall like some falkens etc.....
maybe like mill out the wheels or run camber
Quick Reply: volk CE28 18's need tire but what size?
