Varrstoen wheel fitment?
Hey I'm wanting to get some varrstoen TE37 (I believe they're called the V2's) replicas for my S. Problem is all of the sizes are VERY aggressive for our cars. The most s2000 friendly setup I found was 17x9 +30. I'm ok with stretching the tires and rolling the fenders and adding some camber, but would that be enough? I'm really not trying to pull the fenders. Thanks
The Miro 398 are also TE37 reps that you can get in 18x8.5 +35 which I'm guessing will probably fit better, you might need just a roll, but if your lowered you might need camber.
Varsstoen also has has 18x8.5 +35/+45, but probably not as concave.
Ill check those Miros out!
Varrstoen makes a 17x9 +35 for 5x100. Your best bet is if you call them and ask if you can make a custom order for a 17x9 +35 5x114.3 bolt pattern which I highly doubt they would do but you can give it a shot. And even then a +35 offset with a 9 inch wide wheel is still on the edge. Lots of fender work and negative camber.
