Unstaggered 17 in wheels
Guest
Posts: n/a
Ok. wrong description. "tech" from discountiredirect.com is telling me that staggered wheels are always better for the s2000. but the wheels im looking for, Enkei J10's, dont come staggered. he says that the unstaggered 17's will fit but maybe i should run a staggered tire setup. Should I do this?the wheels are awesome, but will it effect performance negatively?
Did you think the car was designed with a staggered setup just for grins?
What you get with a non-staggered setup is (WAY) more front grip bias...making it dangerously easy to break the rear end loose. You should really stay with the staggered setup unless you really understand what you're getting into and are willing to do the necessary supporting suspension changes.
FYI...I run a non-staggered setup and am a HUGE advocate for track purposes. I have also performed said suspension changes, however, to take advantage of the much larger front contact patch.
