tuning ecu to tires
Sounds like you're running a tire that is too large in diameter - which is going to throw off your speedometer AND give your car taller gearing (which will make it slower).
The right thing to do would be to ditch the ill-fitting tires, but if that isn't an option, then the yellow box calibrator linked above will work.
