TSW Nurburgring 7.5 or 8...?
Again, what are your goals? If you're just wanting the looks, I would go with stock sizes & consider price options more.
My advice and advice from others is performance oriented, specifically to get more grip all around. And the nurburgring is a light weight wheel, so it seems like you're building a performance set-up... But if that's not at all what you need, than you might be spending too much and not be satisfied with the changes made.
Just need to get a FSB. So for non-staggered, what option would be best?
Depending on your wants/needs/usage, 255 fronts might be warranted, but it doesn't sound like it to me.
Originally Posted by calvinnnnn' timestamp='1337007730' post='21696342
Now that I've read around, a non-staggered setup seems to be the way to go. Just need to get a FSB. So for non-staggered, what option would be best?
See my sig. I run 17x9+63, 255/40 all around. Did hit lca under full lock which does happen quite a bit (making u-turns, ocassionally from backing out of parking spacers). A 3mm front spacer solves this issue.
That should fit easily. You might consider 255/40-17 rears, which are more of an ideal fit on 9" width, but 245 is a good fit also. You'll have TONS of clearance in back. It will be closer to the fender lip up front, but I doubt it will be an issue, and if by chance you did get minor rubbing you can dial in some negative camber. But I'd be surprised if that were the case.
I just bought a set of the nurburgrings. The matte bronze is on back order. But get the gunmetal!! It looks lighter on person. It's a sweet wheel. I went with the 17x7.5 17x9 +63. That's the perfect size. It looks great
