trying to find a full dish "smoothie"
I take it back, I do have something to contribute. If you say rolling fenders is not an issue you might look at the Unique wheels. They have a 16x8" in the right bolt pattern. The offset is low, but with the mild width and some real camber you might be able to make them work. http://www.uniquewheel.com/catalog_pg6.html
They only list a +13 offset in 16x8. The backspacing on it would be ~5". That is a pretty low offset for these cars and will extend out ~6cm farther than the stock wheels (on an AP1 anyway). If they can make you a higher offset that would keep you from having to do a ton of fender modifications. Personally I would see if they can do a custom 16x9 +45 or +50 depending on the tires you want to run.
TheRealRS2K
02-22-2012 12:05 AM
