Trofeo R vs RE-71r
#21
I only did ~1/2 track day on the PSSs early on in their lives, and they were OK for a couple/few laps, comparable to the Z1 *Spec street tires I had before.
I know people worship the MPSS, but in my experience they were initially OK but turned into utter garbage after a relatively short time.
The RE71r is generally only available in smaller sizes, the largest being a 285/30-18 and a 295/35-19. The NT01 on the other hand has mostly large size, going to at least 315 and up to 335 widths in 17, 18, 19, and 20 inch diameters. They are probably designed around different weight and HP cars.
What sizes are you planning to use?
#22
-3* front camber, 0.1 degree total front toe-in, 5.4* caster
-2* rear camber, 0.1 degree total rear toe-in
37psi hot pressures (~30 front 28 rear cold)
Of course they'll last a LOT longer than 1000 miles on the street. But if you have 5.5 lb/hp and just let the back end hang out when you get wheelspin on a track like TGPR (coarse/abrasive surface), you might end up surprised at the rear tire wear/erosion rate...
#24
Originally Posted by jst2878' timestamp='1468503541' post='24016344
Im sure your alignment was way off and your pressure was too high on the re-71. They last much longer than 1000 miles and a 29 cold is a good place to start for grip.
That doesn't mean the RE71r is the right tire for a 500hp car on a gritty track, but it might have been running in a sub-optimal configuration.
#25
The STR S2000s typically run 12kg/mm-16kg/mm springs in addition to a big front bar. Camber is -3° or more front and rear. Wins are measured in 10ths of a second, and sometimes less (ask Nick who lost 3 national championships by a combined total of something like 1/4 second.)
-3/-2 is fine for my car and although I am competing in time trials I don't care if it *might* be a tenth slower than -3.5/-2.5 or whatever is truly optimal for a given track for my car.
FWIW the tires wore as near as I can tell perfectly evenly across the tread, no excessive outside shoulder wear or "camber wear" or inside-tread vs. outside-tread wear.
My input: *if* tread life is a factor for you, I'd get NT01s (or Trofeo Rs) over RE71Rs based on my experience.
#29
Saw a guy at my last track day with the trofeo r's and holy crap they are meaty!!
We were both running rpf1's 17x9 with 255's and his tires looked substantially wider than my proxes r1r.
I'm in need of new tires and I was also comparing the two (trofeo r & re71r) but I don't compete in sanctioned events (yet).
I do open lapping days and I'm always trying to best my time so I'm not sure it makes much sense to get the trofeo' after reading this thread.
They're more expensive and they don't last as long but dam do they look good.
#30
I wouldn't have any qualms at all going out with a first-time student on NT01s at the track.
