TPMS?
Old 01-09-2008 | 08:26 AM
Leem's Avatar
Default TPMS?
I will probably get some TR Motorsprt F3s. Will the TPMS still work? If not, can I disable it so I don't have the light on the dash? I have an 2008 CR.
Old 01-09-2008 | 11:26 AM
Jim@tirerack's Avatar
Former Sponsor
They work with the sensors. I am not sure you can disable the system but you may be able to take out a fuse.
Old 01-09-2008 | 11:36 AM
Leem's Avatar
So can I put the sensors on the new wheels or any aftermarket wheels?
Old 01-09-2008 | 03:04 PM
rjones's Avatar
I put on 4 wheels without TPMS sensors and I did not get a light in my 2008 CR. I only drove about 10mi. but turned the car on and off about 10 times. I don't know if this is normal or if the light would come after a longer drive.
Old 01-10-2008 | 11:17 AM
Former Sponsor
The light should have been on right away.
Old 05-04-2008 | 08:00 PM
kuya2u's Avatar
I traded my stock rims for a set of BBS rgr rims andy tpms light didn't come on till 2 days later. Now I have to buy a new set of sensors.
Old 05-04-2008 | 08:10 PM
Sinji's Avatar
you guys should consider putting on tpms adaptors if the tpms will not work on the wheels you're buying. they look like these:
or build one of these pipe bombs. works for lexus' so it should work for the s also:
[QUOTE=combfilter;3173139]This is beyond easy, but I did see people asking the guy who built the first one how he did it so I documented the process.
Old 05-06-2008 | 04:36 PM
milkbubble's Avatar
Wow that TPMS can is awsome!
Old 05-06-2008 | 06:34 PM
s2sik's Avatar
the sensor turned on not immediate, but literally just a few blocks down the road, we plugged the new sensors into a set of te37s and it works perfect now.
Old 05-06-2008 | 06:47 PM
AP2's Avatar
AP2
if the hole for the valve is the same size then they should go right in, if not, then yeas you would need to use/make an adapter
Quick Reply: TPMS?
