Toyo T1-S installation
Old 04-02-2004 | 07:26 AM
ideugene's Avatar
Default Toyo T1-S installation
ummm... i just bought toyo t1s... and im not sure which way to mount them... the treading kinda looks like ">>>>" so would the points face the front of the car so that when the car is traveling the base of the triangle hits the ground first... or should the point face the back of the car so the points hit the car first??
if the car is traveling to the right... would the treads looks like...
thanks!
Old 04-02-2004 | 07:41 AM
zzz36's Avatar
the first one........ >>>>>>>>
Old 04-02-2004 | 08:56 AM
ideugene's Avatar
really? i would imagine the points would have to touch first to tread water out the sides? maybe im mistaken
Old 04-02-2004 | 12:02 PM
TriaXenginE's Avatar
just like that.
Old 04-02-2004 | 08:16 PM
ideugene's Avatar
but look at m777erlin's picture...
from what i can see in the picture he has them like
Old 04-02-2004 | 08:34 PM
dude, he's got them going the right way.
and besides, if you look at unidirectional tires when you get them, there's usually an arrow on the sidewall that shows the proper rotation.
Old 04-02-2004 | 08:38 PM
ideugene's Avatar
am i seeing something wrong?
are you talking about the tire tread or the imprint on the ground? thats going >>>>
Old 04-02-2004 | 08:49 PM
ninegrand's Avatar
I think you are looking at it wrong. Rotate the tire in your mind and you will see the "pointy" part of the tread facing forwards.
Old 04-02-2004 | 09:03 PM
ideugene's Avatar
so the "point" hits the ground first when driving forward?
Old 04-02-2004 | 09:12 PM
ninegrand's Avatar
hell idunno I am just going by the pic you posted. If you look at the picture and rotate it around, then yes the point hits the ground first.
I have no knowledge of these tires but if you were to think about it, rotating the other way would channel water towards the mid of the tire rather than move it out to the sides.
Have you actually LOOKED at the tires? As mentioned earlier, if they are directional they will have a ---> OR <---
