Too small of an offset?
I'm looking at 17x7 (48mm offset) for the front and 17x8 (35mm offset) for the rear, but I'm concerned about the rear offset. Any help?
I have the 16" Spoon wheels with a 45mm offset for the rear, and they rub a tiny bit over large bumps or dips. They are perfectly flush with the fender. I would think that 35mm would be past the fender. Hope this helps.
You can run the 35 in the front but not with a 8 inch wide wheel. The rear will not hold the 35. Your better off getting the 45 all the way wround if you REALLY want those wheels.
