too much tire poke? 9 all around
due to a lot of tire poke, i feel like im going to be rubbing if i lower my car. maybe i need to stretch the tires but im not sure. im already on coilovers and not sure if i can go any lower.
im on these sorry xxr 009 - http://xxrwheels.com/sportmax_009.shtml
17x9 +35.
17x9 +35.
sell the wheels.
okay...seriously...what size tires are you currently running?
You don't have tire poke, you have wheel poke. Really the only way to get them to tuck inside the fender is a lot of negative camber, probably around -3. 245/45 is not helping you either, the diameter is oversized. 245/40 is the proper sidewall height.
Site Moderator
The rear should fit with a good roll and a little flare and some camber but the front isn't going to fit right. Also like others have said the tire size is wrong. You need 245/40/17's.
Site Moderator
On the rear you can but it will need a roll and some flare as well as some camber. The front it alittle to much. I just test fit my 17x9 +43 on my front with 245/40 and they where a little past flush. I think the fronts need to be +45 or higher for easy fitment. _35 is to low.
