Too aggresive?
Too aggresive?
looking to buy a set of wheels and came across a good deal, just wanna clear up if the fitment will work on my S
front 18x8.5 +44 with a 235 35 18
rear 18x9.5 +44 with a 245 35 18
any help would be appreciated.
what would need to be done to pull this off?
Personally, I would not even consider those wheels. What's the point of spending good $$$ to have wheels that you can only mount stock-width tires on?
The rears don't look like a problem, other than I personally think it's absurd to run a 9.5" wide wheel with a 245 tire. 255's would likely fit with a fender roll and camber.
But the fronts don't even look to be in the ballpark for 235's even with max camber and fender rolling.
I would go with 215/40-18 fronts and either 245/35-18 (safer) or 255/35-18 (riskier) rears.
But again, I would never spend money on big aftermarket wheels that I wasn't even able to run wider tires on.
From the stickie:
For the front:
[B]205 tires: +43 offset minimum (6.5
From the stickie:
For the front:
iFRYrICe206
15
10-06-2011 05:27 AM
