Tires: I am so confused!
It's time for tires.
I got 20K miles on the original RE 050s. Yeah, i guess that's alot.
The fronts can last thru the summer, but I need rears NOW!
1. Is it ok to run a different brand on the rear than the fronts?
2. Is there a difference betwwen Bridgestone 050 and 050A?
3 Any thoughts about the Y'okohama S drive' tire for the rears(and later fronts)?
I need help!!
Thank you!
Russ
I need help!!
Thank you!
Russ
I wouldn't replace your fronts if you are sure they can last the summer. It is ok to mix and match, but I would stay in a similar performance rating (Ultra high performance summer, max performance summer, etc)
