tires for 18x8 front and 18x9 rear wheels?
Old 07-22-2004, 08:32 PM
yummyph0916's Avatar
Default tires for 18x8 front and 18x9 rear wheels?
hi i just bought some rims that were 18x8 front and 18x9 rear...but im not sure on what tire width and size to get..can anyone please help? thank you
Old 07-22-2004, 08:44 PM
wortham's Avatar
just posted on it:
https://www.s2ki.com/forums/index.php?showtopic=223014
Old 07-23-2004, 12:54 AM
hmmm that link didn't help much on the exact tire sizes for the rims...
Old 07-23-2004, 05:27 AM
wortham's Avatar
heh how's that? my rims are an 8 (as you mentioned) and i have 225/40/18 fronts. now, my rear rims aren't the same size as yours, but with the above, you're already half way there.
Old 07-23-2004, 05:36 AM
haha thanks, great now i got the first part done....anyone know what size tires i need for the rear? 18x9.... and also, should i stick with a 40 series tire for the front..or can it even go low to a 35 series for a thinner look?
Old 07-23-2004, 09:03 AM
mwy23's Avatar
225/40/18f 255/35/18r
Old 07-23-2004, 02:45 PM
i appreciate your help! so i should get 40 series in the front...i hope that doesn't rub! thanks again you guys
Old 07-23-2004, 04:33 PM
mwy23's Avatar
rubbage depends on how well your wheels will fit the car. if you have an offset lower than +50 on the front, you will rub with a 225 tire*. for the rear, you need something greater than +55.
* this also depends on the tire brand, how squared off the tire is... i only have experience with bridgestone so3 tires, and i rubbed on stock ride height, 225/40/18 SO3 tire on a wheel with +48 offset.
Old 07-24-2004, 03:19 PM
ohh..so having a 18x8 front with 225/40/18 and having 18x9 rear rims with 255/35/18 is perfect right?
Old 07-24-2004, 04:09 PM
Kwando's Avatar
it all depends on offset.
i had the option to get 18X8 or 18X7 for the front with 45 offset. I went with the 18X7 on a 225/40/18 and i don't rub at all. I'm glad i went with the 18x7 instead of the 18X8 cause that would have rubbed for sure.
my rears are 18X9 with a 55 offset and 255/35/18 an it rubs only during full suspension travel. I also have a 2.2 degree camber on the rear.
Quick Reply: tires for 18x8 front and 18x9 rear wheels?
