Tire Wear
Tire Wear
Looking to find some tires that will last longer. I don't really push the car too much, but only got 14000 out of this set of 02's, but front ones still going well. I don't know a thing about performance tires---H, Z, ZR etc.... Need advice!!!!
Gixxer
Gixxer
IMO, 14000 miles is really good for rear stock S02's. S02's are the best street tires you can put on your S2000. If I were you, I'd just replace the rears with some new S02's. Then when they're worn out, you should be good to go for a 4 tire changeout.
In the stock sizes the other tires you might consider are:
Bridgestone S03
Kumho 712
Yokhoma ES100
Toyo T1S
Probably not a good idea to mix front S02's with anything else.
If you don't get the stock S02's make sure you get the more correct rear tire size of 245/45ZR16. See this https://www.s2ki.com/forums/showthread.php?...&threadid=48572
There's a lot of info out there on this, so do a search and make your own choice.
Also, except that they don't carry Toyo's, TireRack is your best bet for pricing and availablilty.
Bridgestone S03
Kumho 712
Yokhoma ES100
Toyo T1S
SilverKnight
07-11-2004 11:17 AM
