Tire SPec. question
Tire SPec. question
is this a good setup in F:225/40/17, R:245/40/17, for the AP2 v1 rim on 2003.
pls i need some comment if this is good or not........or out of ratio spec.
tks,
tks,
You may want to do 225/45/17 in the front. 225/40/17 may be a tad on the small side, but for the most part, it should all fit fine. As for ratios, 225 front and 245 rear is a bit off. You may stick with 215 front and 245 rear, or if you wanna go wider in the rear, 255 works great with 215 or 225 front.
Former Sponsor
I agree, you would be better off with a 215/45R17 and 245/40R17 or 225/45R17 and 255/40R17. The wheel width and offset would be the determining factor.
If I can help let me know
