tire sizes
tire sizes
would larger tires fit on our car with OEM wheels? like 215s in front and 235 or 245s in the rear, can someone give me some sizes that they have tried and like, cuz i am about to buy new tires and i would like to have bigger tires? pls give combo of both front and rears
thx,
kevin
thx,
kevin
depends on the make and model of the car. for instance, a 245/50 Pole Position S02 (which I dont recommend) is slightly - by a few mm - narrower than the 225/50 OEM S02's.
different manufacturers and models vary the size. if you just want wider tires, you aren't going to be able to squeeze anything else on this rim. if you were able to, then it will just add to poor handling because the extra play in the rubber will add to the 'rollover' characteristics of the sidewalls.
Former Sponsor
I would recommend to stay with the 205/55R16 front and go with a 245/45R16 rear. I would not recommend anything wider for the car. If you go to 18" you can go with 225/40R18 front and 255/35R18 rear.
If I can help let me know.
Thank you
Jim 800-428-8355-364
Thank you
