Tire size suggestions for 18x8 +44 and 18x9.5 +45
Just wanted to make sure before I buy a set of wheels for the car.
Car has fenders rolled w/ tabs cut w/ 2 in drop.
Thinking about picking up a set of 18x8 +44 and 18x9.5 +45
What tire size should I get? 225/40/18 front and 255/35/18 rear?
Former Sponsor
With the drop and the low offsets of the wheels the sizes you mention are going to be tight. I would run more negative camber to give more clearance. You would be safer with the 245/35R18 on the rear for clearance but the 9.5 wheels would fit better with the 255/35R18.
If I can help let me know.
In the gallery section if you go into the aggressive wheel thread on the 1st or 2nd page there is a yellow S2000 with 9.5 +38 all around with 245s and all he has is fenders rolled/tabs moved back... It looks like he may have around -2 or 3 degrees of camber though
how much camber did you run? my reason for asking is i have 18 x8.5 + 55 wheels with 275 35 18 tires all the way around but i want to upgrade to some 18x9.5 wheels with 275 tires and it is much cheaper to buy 18x9.5 in + 45 than 55. my rear fenders are rolled and i have 30mm over downforce fenders in the front. And i'm still running stock supension
