Tire size suggestion? Nonstaggered
I picked up some 17x7.5 +41 offset work meister m1 wheels all around, nonstaggered and will daily these. Will run these spring to summer mostly, any tire size suggestions? Will run bigger front sway bar and softest setting on buddy club spec racing dampers (VERY STIFF). Thanks.
225/45-17 square, could run 205/50 or 215/45 fronts if you wanted to stagger the tires.
I wouldn't run 235s on 7.5. 235/45 too tall, 235/40 really wants to be on at least 8.5" wide wheel.
Former Sponsor
If you want to stagger I also like the 205/50R17 front and 225/45R17 rear. If not just run the 225/45R17 all the way around. There are a lot of good tires in these sizes.
If I can help let me know.
