Tire Size Options for 17x10 +30 & 17x9 +20
Old 03-11-2014 | 12:13 PM
s2000Junky's Avatar
Originally Posted by tootrue23
Originally Posted by alphalanos' timestamp='1394508163' post='23056330
Im running 17x10 +22 all around with 255/40 and I have ASM rear flares and widened front oem fenders. Max camber in front on stock adjusters, im not sure in rear probably around 3 degrees.
So are you saying without the flares, your setup would not clear?
What if I run a slight stretch of 245/40 on the 17x10's?
Thanks for your input guys.
That’s right. He has about 25mm more outer clearance. Even with a 245 stretched you would be rubbing. 235/40 would get you there, but that’s dumb on a 10" wheel and tires in that size are limited. Since you would be going through them often from all the camber you will need to run, that may or may not be a consideration. You could just go to the Hellflush gallery and see what your wheels in question look like, im sure someone is running a very similar fitment there.
civicson234
10-21-2008 06:07 PM
SPECIAL-OPS-S2K
05-11-2008 12:09 AM
TriaXenginE
05-05-2008 09:53 PM
duff0000
08-10-2006 09:23 AM
JT-KGY
02-20-2002 12:08 PM
