Tire size for new Wheels
Old 12-30-2010, 07:02 AM
redshooter's Avatar
Red face Tire size for new Wheels
Hi , I just received my new wheels.
18x8 offset 48mm
18x9 offset 50mm
Im dropped on 1inch spring and dont want to rub.
Please let me know what size would be the best its only for daily drive.
Thank You.
Old 12-30-2010, 07:34 AM
NFR_AP2's Avatar
if it were my car id go with a 225/35/18 in the front and a 245/35/18 in the rear
Old 12-30-2010, 07:36 AM
RedCelica's Avatar
I'd go 225/40F 255/35R: Yokohama ADVAN Neova AD08
http://www.tirerack.com/tires/TireSearchRe...ter=18&x=15&y=9
http://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes
Old 12-30-2010, 08:04 AM
redshooter's Avatar
any big difference between 225 /35 or 225 /40 in front
Old 12-30-2010, 08:26 AM
Rubn1out4GudLuk's Avatar
w/ Red Celica
The difference is a little more sidewall on the 40 series.
Old 12-30-2010, 08:48 AM
RedCelica's Avatar
40 series on the front with 35 on the rear will give you a more balanced feel and encourage what I like to call "cornering neutrality." Basically, the front tire will flex a little more and dig in, where the rear will be nice and stiff. Since the rear has a larger contact patch than the front though, you can roll more on the throttle when exiting a corner while keeping the front from sliding.
Old 12-30-2010, 08:59 AM
1nate7's Avatar
I don't follow your explanation but I agree that 225/40/18 and 255/35/18 are the way to go. They have the exact same sidewall height which is the goal if you want to keep stock like handling (staggered width/same diameter) with a little extra tire width. I suspect you will rub though, especially in the rear with a 255. You could also do 215/40, 245/35.
Old 12-30-2010, 09:05 AM
RedCelica's Avatar
You're right, the sidewall height will be the same, but the front tire is going to have more give than the rear at initial turn-in. He's only got a 1 in drop, any lower and I wouldn't have suggested the 255s, but I dont think he should have a problem. OP, what is your camber front and rear currently set to?
Old 12-30-2010, 11:32 AM
redshooter's Avatar
if i want to be sure i can go with 215/40, 245/35 then ? or the 225/40/18 and 255/35/18 is fine and will do it because now im confused on what to choose between those 2 ssetup
Old 12-30-2010, 11:36 AM
RedCelica's Avatar
I guess I'm really pushing for 225/255 b/c I find it a little frivolous to buy nice 18s with increased wheel width over stock and keep stock width on the tires. jm2c.
Quick Reply: Tire size for new Wheels
