tire size help
tire size help
So my 17x9.5 te37 came with Dunlop dz101. 255 40 17 x4. There was some stretch on these. I replaced them with 255 40 17 Hankook evo2. These are bulging a bit. I want to get the same tiny stretch like the dz101 for my front however I'm not sure which tire size will work. From what I have read the dz101 runs small. I'm torn between the same evo2 but 245 or 235. I have a bad feeling the 235 may be too stretched and the 245 no stretch at all. I've seen pics of a 235 on a 9.5 with very tiny amount. I've also seen a 235 on a 9.5 with ALOT. Any help will be greatly appreicated. I'm adding pics of the before and after. Both are 255 40.
Here's the Hankook
here is Dunlop
Here's the Hankook
here is Dunlop
I think both look fine and you may be over analyzing things. Perhaps, choose the better tire and stick with that?
I would stay with a 255, no smaller than a 245 if since you're running a 9.5 width. I would NOT run a 235 on a 9.5, it WILL stretch!
I'm not going based off looks.
I chose the Hankook tire. I just didn't realize when I picked 255 that the Dunlop ran small. I need a tire that's similar to the Dunlop in size so I don't rub upfront.
