Tire size for front 17x7.5 +50 rear 17x8.5 +47
Old 02-23-2022 | 11:48 AM
k0be's Avatar
Default Tire size for front 17x7.5 +50 rear 17x8.5 +47
Looking for suggestions on tire sizes for some CE28N wheels I'm looking to pick up locally. Its :
Front:
17x7.5 +50
Rear:
17x8.5 +47
Currently running stock AP2v1 w/ an inch or so drop
Front:
17" x 7.0", +55 offset w/ 225/45/17
Rear:
17" x 8.5", +65 offset w/ 255/40/17
Don't mind rolling fenders or running a bit camber but just wondering what are some of the best tire setup suggested by you folks for these specs (and if it will require any rolling/camber/max or min drop) since the rears are a bit lower offset. Thanks in advance!
Old 02-23-2022 | 12:27 PM
VeeDub's Avatar
You can run those same tires specs as what you have now. I have slight rubbing on fast dips with 255 with 8.5 +50 rears even with ~2.8 rear camber on unmodded fenders. You might get away with no rubbing with 245.
Old 02-23-2022 | 04:41 PM
B serious's Avatar
You shouldn't need much to make that wheel set clear.
Though its important to note how you're lowered. A full body adjustable coilover retains travel at lower ride heights. A single point adjustable or stock shock does not. Big difference.
Tips ..Never turn the front wheels at a high angle while going up a driveway or something.
Cut off or roll up the front tabs.
I'd use stock AP2 tire sizing of 215/45 front and 245/40 rear
Or 225/45 front and 255/40 rear.
Coma-02SK
10-25-2012 02:26 AM
Devinb
04-03-2011 10:08 PM
Fuelrush
02-14-2007 12:50 AM
x s2k x
01-14-2006 09:39 AM
s2000flog
07-27-2005 06:46 PM
