Tire size confusion
Okay, So I'm beginning to look at some summer performance tires and I really like the star specs but I am unsure about the sizing because of a post I read. I know the fronts are 205/55/16 but I read that if running a non-oem tire on the stock wheel, the tires size should not be 225/50/16, but rather it should be 245/45/16. So, should I be ordering 225/50/16 star spec's for the rear or 245/45/16? I did read the stickies, I just got confused when trying to understand them.
Thanks for the heads up, I was looking but didn't see a 245/45 size so I figured it had to be the 225/50. Another question, what are some thoughts on the star specs? Good tire? How does it wear?
Former Sponsor
The Star Spec will wear about the same as the stock tires. They will be around 15K on the rear depending on how hard you drive the car.
If I can help let me know.
Thanks Jim, I probably be giving you a call at the end of summer as my car moves from PA in the summer to Florida in the winter. Even thought he ones on right now are in good condition I would like to get a new set before the trip.
