Tire Size Assistance Needed
Old 05-14-2007 | 01:57 PM
thonda's Avatar
Default Tire Size Assistance Needed
Front Wheel 17x7.5 45mm offset
Rear Wheel 17x8.5 48mm offset
Can I do
225/45-17 Front
255/40-17 Rear
Without rubbing?
Or is
215/45-17
245/40-17
the way to go?
Thanks!
Old 05-14-2007 | 02:26 PM
aggie's Avatar
I would go with the smaller set
Old 05-15-2007 | 04:22 AM
thonda's Avatar
will the 255/40-17 rub w/ the rear wheel set-up?
Old 05-15-2007 | 03:06 PM
PJCC's Avatar
With OEM suspension and assuming original tires are 215/45R17, you can do both, 215/45R17 and 225/45R17. The same goes for the rear. Assuming 245/40R17, you can do both 255/40R17 or 245/40R17.
Go to http://www.rims-n-tires.com/rt_specs.jsp and double check-it.
Old 05-15-2007 | 04:20 PM
CaptainMike's Avatar
With those offsets, I'd stick with the 215/245 combo, you'll be fine at stock height and have some room for a drop.
The 225/255 is going to have substantially reduced clearance, it'll probably be OK at stock height, but you MAY rub with any drop.
Pro-PC
05-10-2010 09:52 AM
GpWaP1 s2k
04-07-2010 03:04 PM
Abe00s2
04-13-2007 09:09 PM
TelosHedge
03-01-2007 06:48 PM
Fuelrush
02-14-2007 12:50 AM
