Tire Size?
Old 11-15-2005 | 05:03 PM
triumph87's Avatar
Default Tire Size?
I just picked up a set of 3rd gen rx-7 rims, they are 16x8. What would be the ideal tire size to keep handling the same or better?
Old 11-15-2005 | 05:32 PM
NotoriousGQ's Avatar
offset? is it 16x8 all around? or just for front or rear?
Old 11-15-2005 | 05:33 PM
xviper's Avatar
Do RX-7 rims fit an S2000? Same bolt pattern? How about offset?
In any case, an 8" rim may be too wide to put on the appropriate sized front tire for this car. Some owners have gone with a 225 up front and this will be OK for an 8" rim. Then you can go with a 245 or maybe even a 255 for the rear. None of these will be "ideal". This is all assuming that the offset on those rims are adequate for S2000 application.
Having the same width of rim on all 4 corners is not ideal, but will work. It is doubtful that you will find any combination that will be as good (let alone better) than OEM sizing with SO2s.
Old 11-15-2005 | 08:52 PM
dangdatsdanny's Avatar
245/45/16 is what im runnin on my 16x8 rear
Old 11-15-2005 | 09:01 PM
xviper's Avatar
Is OK. 255 might be a bit of a stretch but still "OK".
mtm864
01-25-2009 12:16 AM
radtech
01-27-2008 05:03 PM
still
03-20-2006 12:35 PM
LudeAtic
01-26-2005 01:59 PM
evo190
07-15-2002 09:06 PM
