tire rotation
Originally Posted by mas,Dec 20 2004, 03:31 PM
craig_wagner: I think you are talking about asymmetric unidirectional tires? Stock tires are not asymmetric so both edges are the same. As long as you get the direction of rotation correct, there should be no problem.
I call it "flipping" the tires. I wrote up a thread about it some time ago:
https://www.s2ki.com/forums/index.php?showtopic=128526
Many moons ago someone told me that you can't change the wear pattern of a tire. IIRC I had a tire wearing unevenly and went to a shop inquiring about an alignment and was told that even if they corrected the alignment the tire would continue the current wear pattern rather than evening it out.
Also, you specifically state that the tire is flipped on the same wheel and the whole shebang gets put on the other side of the car. What is the advantage of that vs putting the tire on the other wheel so the wheels stay on the same side side of the car but the tires switch sides?
Flipping the tire is not an adverse procedure since the tire still spins in the same direction. Because of the natural high camber of our car, it just wears more on the inside portion of the tread unless you track the car, in which case lateral g's can equalize the tread wear (I suppose that's why the high camber - to plant more rubber in track conditions). For your average street driven car, the outside still wears but not nearly as much. Flipping just puts the remaining "good" tread where it's needed. This is contingent upon doing the flip while there is still some useable tread on the "worn" side. I don't think a tire has a "memory" as to which portion of the tread wears faster.
Originally Posted by xviper,Dec 21 2004, 10:14 AM
Because of the natural high camber of our car, it just wears more on the inside portion of the tread unless you track the car, in which case lateral g's can equalize the tread wear.
Also, depending on which direction your track goes, one side of the car may show a lot more wear than the other side.
Originally Posted by l8brakr,Dec 21 2004, 01:18 PM
The only advantage would be that rim is already on the tire machine, why take it off when you can just flip the tire and remount? Instead you would have to take both tires off then inspect the tread to figure out which way they are to go back on since you set them next to each other on the ground and can't remember which rim they came off. Sometimes things are simple for a reason don't over think them.
marshall
05-16-2005 02:40 PM
