Tire question with Rims
Old 03-14-2006 | 02:58 PM
JayStyles662's Avatar
Default Tire question with Rims
I am looking at the ASA rims As1 I belive...I am also looking at a set of Yokohama Avs100 to go along with that....I know with the factory wheels on the ap1 when you replace your tires with aftermarket you should go with 25s in the rear....How with this combo work out? are the tires too small for the 17? I want my car to handle better or the same as it does now...thank John
Old 03-14-2006 | 03:06 PM
xviper's Avatar
You give so very little information for anyone to really help you out. You need to state the ASA rim specs (width, diameter, offset). It can't even be said if these things will even fit on an S2000 let alone what tires will fit on them.
The "odd" sizing for the rear tire is ONLY for the OEM 16" tire. If you go to a 17" tire, you need to look at OEM sizing for the AP2. Again, not enough information.
Old 03-15-2006 | 07:20 AM
Sorry about that this is all the info that I got from Tirerack....Will I still need to go with a 245 in the rear so keep the same balance as OEM?
And will this effect handling. Another option is to by the BBS LM but that will take a while I can have these next week. and they seem to be a pretty good quality rim for the price....Thanks again John
Finish Shown: Black w/Mach Lip
Other Available Finishes:
Silver w/Machined Lip
Size Selected: 17x7Front
Price: $179 (each)
Estimated Availability: 04/14/06
Recommended Tire Size: 205/50-17
Wheel Offset: +48mm
** Lightweight: 21.2 lbs. **
Size Selected: 17x8 Rear
Price: $189 (each)
Estimated Availability: In Stock
Recommended Tire Size: 225/45-17
Additional Specs
Bolt Pattern: 5-114
Finish Warranty: 1 Year
Country of Origin: South Korea
Construction Type: LP Cast/Shot Peened
Old 03-15-2006 | 09:16 AM
xviper's Avatar
Those offsets will work but they are on the low end (marginal). Thus, this may be the reason for the conservative tire size. I think you can go 215 on the front. For the back, it doesn't say what the offset is, but if it's over +50, you should try for a 245 tire. I don't think TireRack would sell you a rim that's meant for an S2000 if it was grossly out of acceptable spec. This will give you more or less the same sort of rubber balance as the OEM setup for 17" rims, although the offsets are less.
Old 03-15-2006 | 09:25 AM
spa-zz's Avatar
If you put the AP2 into Tirerack's site, they recommend 215/245.
The rear offset is 45. It'll be close.
Old 03-15-2006 | 10:01 AM
xviper's Avatar
This being the case, I'd stay away from it if the car was lowered significantly.
Old 03-17-2006 | 09:02 AM
Thanks for all the advice guys....I might lower it an inch but nothing more and thats will probably be using the Pss9 or T1R System...I have one last question
I am thinking of going with Yokohama AVS100...Anything I should know about these tires? thanks again John
siadam
07-10-2008 12:57 PM
xxlap1xx
09-13-2007 06:38 PM
quicksilver
01-18-2007 05:49 PM
BeachBum
05-24-2005 06:00 AM
Chitah831
12-18-2004 03:11 PM
