Tire question
Tire question
Is that ok to run? that's closer to stock (sidewall height FR bias) than the 255/40 all the way around, right?
or is it better to run 255/40 all the way around, and then 245/45 all the way around?
I have a lot of tires I have to burn through, so trying to find out the best way
I dont race, and wont be getting a bigger sway bar any time soon...
So how come 225/45 is ok up front with 255/40 out back?
Ill probably end up trying it out anyways, have 4 rs3s (255) and 4 re01rs
The diameter of the 225/45 is equal to the diameter of a 255/40, I am wanting to say they are both 25". But the diameter of 245/45 is almost .5 inch larger than that of a 255/40. Iirc there is a .8 inch difference between 245/45 and 245/40. The 245/45 has a lot of sidewall. Tire rack has the exact diameter measurements under the spec section of the tires if you want to double check. These measurements will vary based on tire manufacturers. Hope this helps
Because the second number in a tire size is called the aspect ratio or profile. This is a ratio of sidewall height to section width. Therefore, a 225/45/17 is the same overall height as a 255/40/17. If you did want a slightly more narrow tire up front for clearance or something, then you'd run 245/40/17 F 255/40/17 R.
A 245/45/17 would be 245*.45 which is 110.25mm sidewall...this is an extra 20mm which means the overall diameter would be almost a whole inch taller...the tire would be taller in the front than the 255/40/17 in the rear.
