Tire options for my LE37T's
I am running 225/40-18's in the front right now. My question is should I replace them with 215/40's or 215/35's? I'm trying to minimize damage to my front finders! Thanks!
Originally Posted by TelosHedge,Mar 2 2007, 04:14 AM
215/40's i believe are the correct size. if you dont want to downgrade your wheels you can always slap on some wheel spacers...
Dream, With the TE's offset I'd use the 215 front and 245 rear setup.
Originally Posted by Ubetit,Mar 2 2007, 05:39 AM
Before you give advice do you even know what wheel spacers do?.... wheel spacers would make it worse.
he didnt say TE's he said LE37T's which is the same wheel Im running- and Ive never gone 215 on the fronts-
Im running 225-40-18 up front and 255-35-18 in the rear dropeed on Espelir springs
Alignment is
Front
Camber: -.5
Caster: 6
Toe 0.0 to 0.2
Rear
Camber: -1.5
Toe: .2
No real rubbiing issues-
Alignment is
Front
Camber: -.5
Caster: 6
Toe 0.0 to 0.2
Rear
Camber: -1.5
Toe: .2
