TIRE HELP! .....wild 0ffset
I need s0me help finding the right tire size for a set of rims that are 17x8 + 30 and 17X9 +35 with rolled 0ut fenders. Thanks for any info.......not your typical set up
the offset is not typical yes but the size of the rims are sorta
sizes you can use are 235/45/17 for the front and 255-265/40/17 for the rear. Offset doesnt effect tire sizing.
Crazy setup tho! What rims?
[QUOTE=EternalLx,Feb 11 2008, 06:50 PM] the offset is not typical yes but the size of the rims are sorta
i would run 225/45/17 up front and 245/40/17 in the rear. one of the SD guys ran a more aggressive set-up vs-xx and he cleared all day. and just a little fyi to imnotcreative, the sidewall is an aspect ratio (its a percentage of the width). so you really cant say add 5mm to the sidewall to move from a 40 series tire to a 45 series tire. its a 5 percent increase.
