tire help
tire help
I'm an buy a set of Work TE30s 17x7.5 and 17x9 in the back. I need help with the tire sizes. What would you recommend? I mainly need help with the second number... 225/____ thanks
Geoff
Geoff
I don't know what offsets your wheels have, but if they are S2K specific you should be running 215/45 or 225/45 in the front and 245/40 or 255/40 in the rear depending on the manufacturer and what you are lookig for in terms of balance, etc.
The 1010 tire .com calculators will tell you that wheels that are known for certain NOT to fit on an S2K will fit just fine, so take what you see there with a grain of salt.
Cheers,
Mike
Cheers,
Mike
Former Sponsor
CaptainMike is on the money. The tie size you choose would be dependent on the offsets of your wheels. You have a lot of options in both set ups. If I can help with the secific tire let me know.
