Tire Choice help
Tire Choice help
I've been looking all around and cant see to find much on my issue. I got an S2000 that was previously owned by a Sup Bruh Stretch is lyfe..Check out my 18x9.5 rims wrapped with some 215/40/18 kid and im trying to bring it back to a flush look. I have a set of 255/35/18 that I want to throw on the rear and buy a set of either 225/40/18, or 225/35/18. Does anyone have a setup like that? Will the thickness of the tires even be noticeable? The fronts are 18x8.5.
What are the offset of the wheels? They're likely stretched for a reason, putting wider tires on may just destroy your fenders.
Why don't you just get new wheels? Car is going to look super weird on those wheels/tires with a high height.
225/40 would be the correct front tire size to match the 255/35 rear diameter. As mentioned, you can make it work but will require some effort. A compromise that might be worth considering is 215/40 front, 245/35 rear.
yea but I have a set of 255 for the rear so I'll only have to buy 225 for the front. Anyone have a pic of 225/40 in the front and a 255/35 on the rear. I just want to see if it will look funny.
Former Sponsor
The front tire size should be a 225/40R18 not a 225/35R18. The 225/40R18 retains the same height as your rear tire and will keep the car balanced and the anti lock brakes working correctly.
