Tire Break In
Old 05-01-2006 | 09:05 AM
Spec_Ops2087's Avatar
Default Tire Break In
Anyone know what a good rule of thumb is for the tire break in period.
I have brand new Goodyear Eagle F1 G3-D3s on my new rims and I've put about 150-200 miles sofar on them and the car still feels pretty light on turns. I also did a launch last night (about 100 miles on them) to see if they were starting to grip and I spun all the way through first.
Hopefully someone can come here and tell me they'll start being sticky soon becuase I hope they don't stay this unstable.
Thanks
Old 05-01-2006 | 09:31 AM
Jim@tirerack's Avatar
Former Sponsor
Around 500 miles depending on how hard you are driving.
Old 05-01-2006 | 09:40 AM
aggie's Avatar
Don't forget that your air pressures could be wildly wrong from the tire installers. Spinning all the way through first should break the tires in
Old 05-01-2006 | 03:51 PM
Well I check the tire pressure after it was sitting in my driveway for a while. All 4 tires are a 40 PSI which I think is a bit high. Jim, do you know what a good PSI would be for these tires on 18s for the s2000? I was thinking 35 ish?
Old 05-01-2006 | 08:18 PM
Vanos954's Avatar
Car tires are good to go after a few miles (less than 100 anyway). Drive them relatively hard while realizing the mold release stuff is kinda slippery and be prepared for it to get a bit out of shape. Get them to roll over a bit in hard cornering to get the slickness off the part of the sidewall you can get onto and you're good to go.
Old 05-01-2006 | 11:22 PM
s22k's Avatar
most user's manuals states 200 miles as the break-in period. if you drive hard, 100 mi is probably enough, if you drive like grandma, 500 mi. i have used a few sets of those tires, they are great tires for the money.
Old 05-02-2006 | 04:03 PM
CaptKirk's Avatar
It took me something like 300-400 miles to break in my goodyears... A lot of that was easy driving with some aggressive driving.
Old 05-03-2006 | 08:34 AM
aggie's Avatar
40 psi reduces your tire contact patch to the center f the tire - not good. Start with 32 psi and possibly adjust up from there.
Old 05-03-2006 | 04:13 PM
Yeah currently my tires are running 35PSI cold and it definatly is better then 40 PSI cold. I might even back it down a little more
TopGear
04-14-2010 01:25 PM
S-EMPIRE
04-07-2008 02:25 AM
Ubetit
12-13-2006 08:01 AM
BerlinaBayRidah
07-06-2005 10:39 AM
NoBy
04-06-2005 12:23 AM
