For those w/ NSX wheels on their S2K
#23
Just did a quick look of the nsx rims and here's the specs / tires I have:
17x7, +60 offset running 215/40/17 tires up front
17x9, +56 offset running 255/40/17 tires in back
Pics coming soon,
rk
Pics coming soon,
rk
#25
Just mounted them b4 breakfast....
The rears fit almost perfect with about 1/2 finger gap to the rear fender in terms of width.
The fronts are a bit tucked and could use a 5-10mm spacer to bring it out a bit. The 215/40 tire I have up front is slightly thinner than the oem ap2 size (215/45) so I may have to drop the front a bit as the gap looks larger.
Anyone else run a 5-10mm spacer?
rk
rk
#27
here's some pics as promised with 2 notes:
The rear nsx wheel center caps don't fit on an s2k wheel unless u use a small spacer. Also the rea NSX tire fitment 255/40 is TOO THICK for an s2000 and I will probably need to go 255/35 or a 245/40 as mine rubs really bad on bumps right now.
enjoy
rick
enjoy
rick
#30
Originally Posted by Fastfour,Sep 28 2008, 01:41 PM
Damn, that looks so good. Does it rub in on the inside or outside on the fender?
Wyatt: I actually really like the exact Prodrive setup in your sig!
rk
