For Those Running 5mm Spacers
I would love to know about this as well since I wouldn't mind a 3-5mm spacer on my stock rims....
here's a picture of my 25mm H/R spacer with integral studs. This is the safe method from what people tell me if you want large spacers.
if it takes 4 rotation to tighten then i would get longer studs for sure...then if they are too long just nut them and cut to size... if you are going large with the spacers then the above option (pictured) would be best..
Sorry for this shameless plug ...but I'm selling my brand new, never opened 5mm H&R Spacers here:
https://www.s2ki.com/forums/index.ph...f=107&t=632676
I test fitted the H&R 5mm spacers on my rears last night (center bore is too large in the front for them to fit flush against the hub) with stock wheels and got barely under 5 turns w/ finger tightening. I proceeded to torque them down but haven't driven on them yet. I'll report back on how it works out.
I attempted to place the longer studs I have on the car but it appears the hub has to be removed in order to do so.
Zach
Zach
