Are these mixed tire names O.K. on my new to me S2000?
I just got my first S2K this morning. Very Exciting!
My first tire question is this:
It came with Bridgestone Potenza's on the back and Bridgestone Turanza on the front. Both sets are in nice shape.
Is this anything to worry about? I had always heard it was best to have the same tire all the way around.
Thanks
Thanks
The Turanzas are more of a touring tire (mileage oriented not ultimate grip or performance) while as the Potenzas are more performance oriented depending on the Potenza version (S04, RE71R, RE980 AS).
Is this a safety concern...not really...it won’t be balanced front to rear but if you drive conservatively then it would be fine. The point is that you bought a performance car, why not put the best performance tires on it?
Personally, I’d buy matching Potenzas and then sell the new Turanzas so you at least have a matching set. This coming from someone who works in the tire industry and not for Bridgestone.
Tires can sometimes 'flat spot' after sitting in a cool environment for a few days without being driven but generally the flat spot goes away after a few minutes of driving. If the tires were recently put on, it could be a balancing issue at high speed. Or last, it could simply be a loose suspension,worn out bushing, or wheel bearing going out.
There are *many* quite different tires labled "Potenza" and likewise many quite different tires labeled "Turanza". For sure you have differently-performing tires on the front and back of the car, but without more info impossible to say how different they are.
What are the *specific* tires you have (Potenza RE71R?, Turanza EL400-02?)
What is your usage envelope? (possible you might need to drive in cold/snow? Track usage a possibility?)
What do you want out of tires? Max life, max wet and/or dry grip, low noise, comfort, responsiveness, etc.
Tires will have a HUGE impact on how much you enjoy the car and on safety, so it's probably worth figuring out what's best for you and if necessary getting 2 or 4 new tires.
That said if the mismatch isn't too ridic, and decently matched to usage conditions, and you are fine with them, I wouldn't worry about just using them and enjoying the drive...
https://www.s2ki.com/forums/s2000-ta...od-one-629997/
If its me, I'd be getting a full set of new tires and a good alignment at oem specs as soon as possible. These two things combined can make a huge difference in the performance and enjoyment of the car.
While your at it check out the suspension components. Pogo stick sounds weird. Get to the bottom of that asap. I don't know if you are used to rear wheel drive sports cars, if not, be careful and drive as if you are on a motorcycle until you get used to the car. It can be a bit of a handful if you are not used to such cars.
Thanks for the advice. I do come from a rear drive background, BMW's, 944's, 968's and the like. But I am going to still take it easy until I get new tires in the spring. We are down to just a few more weeks of driving before it goes into storage.
I only felt the bouncing thing on one road surface but I will look where you advise, and report back.
