Te37 wheels
Te37 wheels
Anyone know if 17x7.5+40 te37's will clear spoon calipers and will these wheels fit w/o rolling my fenders? I want to run 215/45 re11's
Thanks...
Thanks...
Originally Posted by Manga_Spawn
You will need to roll your fenders. Not sure if they clear the brakes.
Site Moderator
Those will be fine. The fronts need to be rolled because of the higher offsets and because the wheel turns.
Site Moderator
Sorry I meant lower offsets on the fronts and you should roll them especially if you are lowered.
For the rear if you want them flush I would do a 10mm and roll the fenders and relo the bumper tab. 15mm could work but it will be much tighter if you don't want any camber.
Sorry I meant lower offsets on the fronts and you should roll them especially if you are lowered. For the rear if you want them flush I would do a 10mm and roll the fenders and relo the bumper tab. 15mm could work but it will be much tighter if you don't want any camber.
