Straight to the point.
I want to upgrade my wheels and tires to 18". What size tire, width and offset would you guys with 18" suggest? Do I have to do larger in the rear then in the front? Or can I go with the same size all around? Like 225/40/18? I did a search and I could not find any straight and simple answers.
Much appreciation
Much appreciation
Former Sponsor
There really is no straight and simple answer. You can run a number of different wheel and tire sizes in the 18" on the car. The offset is going to be around 48mm front and 55 to 65mm offset rear. The 225/40R18 front and 255 or 265/35R18 rear are all good choices.
If I can help let me know.
Thank you
Jim 800-428-8355-364
Thank you
Thanks, Jim. Good to hear from a fellow Hoosier. Can I do the same size front and rear and still be ok? I really don't want to go that big in the rear. I appreciate the help and will contact you when I find something out further.
Former Sponsor
I suppose you can do the same size but I don't think it will have an advantage for handling on the car. As long as the tires arre the same height front and rear you are ok on the car. The 225/40R18 alll the way around will work on the car.
Thank you
Jim
Thank you
Jim
