Storing Bridgestone RE-11 tires in unheated garage
Is it okay to store summer tires in my unheated garage? I have a set of Bridgestone RE11 tires that have been taken off the car and are sitting in the garage. I don't know if the cold will cause them to crack. (The temperatures where I live can get as cold as -40 degrees Celcius)
Or the indoor freezer,be warmer in there also
http://www.consumerr...cking/index.htm
From Tire Rack:
My tires remain off the ground so they don't flex. And my garage remains above 20°F pretty much all the time.
-- Chuck
From Tire Rack:
It is not recommended to drive on these types of tires at temperatures below 40 degrees F (5 degrees C).It is recommended these types of tires be stored indoors at temperatures maintained at above 20 degrees F (-7 degrees C) when not in use.
-- Chuck
Interested to hear more on this. I have 4 RE11As stacked in my garage waiting for wheels. Care to elaborate on the negatives to this? Thanks!
Originally Posted by iridedumped' timestamp='1447474486' post='23803189
[quote name='noodels' timestamp='1447453186' post='23802987']
chuck is right, off the ground and no pressure.
[/quote]
Stacked on the sidewall should be fine, its when they are upright on the tread for long periods of time, that you will get a deformation/flat spot in the tread, which may or may not totally disappear once mounted, certainly can make balancing a challenge.
Destiny2002
04-18-2003 06:47 AM
