Stock wheels...new tires...
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
I think I am going to pick up some kumhos due to $$ issues. I have searched but get diff answer...ok...so I should go with 205/55/16 front and 245/45/16 rear?
Thanks for your hlp!
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Yes, that is the correct size for non-OEM tires. The OEM rear tire marked 225/50/16 actually measures as wide or wider than aftermarket tires labelled 245/45/16. Use the latter size to maintain correct front/rear stagger in tire width. The OEM front tires are similar in width to aftermarket tires labelled the same (205/55/16).
