Stock suspension alignment specs for aftermarket wheels/tires?
Jim or any wheel/suspension expert,
Rims are 17x7.5 front with 225/45/17's and 17x8.5 with 255/40/17 in the rears. Offsets are +48 in front and +54 in the rear. Question is how appropriate is stock alignment to my set up? Should I go with different alignment specs? What would you recommend street/track use? If you have a recommendation can you be specific so I can bring it to the shop?
Thanks for any info,
Ed
Ed
Former Sponsor
You would want to run more negative camber to fit the rear tire on the back. You may also want to run the least amount of toe in on the rear that Honda recommends. This will improve the tread life.
If I can help let me know.
Jim 800-428-8355-364
hyperpm
02-07-2004 06:24 PM
