Stock front on s2k
Stock front on s2k
Has anyone tried to put on 225/45/16 on the front stock rims? I am about to replace my oem tires and is looking to get wider traction in the front. Please give me your experience and advice on such setup.
225/50/16 fronts and 245/45/16 rear will work fine as long as you have a very stiff front sway bar, about twice as stiff as the OEM front sway bar.
Unless all you care about is winning a drifting contest.
Also the fronts in 225 will bulge alot, the OEM rim is only 6.5 IN wide.
